주요 콘텐츠로 건너뛰기
Android smartphone with a 5.15" 1080p display and a Qualcomm Snapdragon 820 processor. First released in 2016.
48 질문 전체 보기
Phone not turning on, no leds blinking at all!
My mi 5 was rooted and was installed with aosp rom. I downloaded a battery calibration app, where it was instructed to start calibration and then when the phone switches off it should be charged to a 100 percent. I had unplugged my phone at 97 percent, but I couldn't switch it back on. There were no leds or anything. I also tried to charge it but now it wouldn't show anything . How can I fix it?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 7개
me too i have the same problème.
Hi,
I had a similar problem, my phone turned of and I wasn't able to turn it on, or charging, there wasn't any leds.
I repaired it by opening my phone (very easy) and unpluged an repluged the battery connector.
I think there is a generic default with xiaomi mi5 battery...
Hope it helps !
Wow great answer Geoffrey had the same exact problems and followed your advice found a tutorial on how to disassemble a xiomi 5 on you tube opened it unplugged replugger the battery and now it works !!!!!
Thanks again Geoffrey I how you a beer !
I have the same problem. Any solution?
Dizefurkan,
You can open your phone and unplug then replug the battery connector (you will easily find a tutorial for it), I made this a few times, but I think, it's just a temporarly solution, mine juste completely die after 8th times...
댓글 2개 더보기
댓글 달기
답변 3개
가장 유용한 답변
Hope it helps !
by Geoffrey Borelli
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Hi
Try yo flash marshmallow roms via fastboot or mi flash
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
will it work?
댓글 달기
Hello,
My Xiaomi Mi5 had a battery drainage. It was heated so much that I was not able to hold it. After some few minutes, it turned off and I was not able to switch it on. I tried to charge it; no led glows. Its just like a dead mobile phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
i am facing such type of problem, started with unresponsive touch screen . now it totally dead
Did you solve the problem?
댓글 달기
귀하의 답변을 추가하세요
Fragout Gaming 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 12
30일 전: 56
전체 시간: 6,485
