주요 콘텐츠로 건너뛰기
모델 A1200 with 2.16 또는 2.33 GHz Core 2 Duo 프로세서
113 질문 전체 보기
iMac 24" A1200 power supply pinout?
Hi all!
A friend of mine gave me a broken imac 24". I would like to recycle the power supply for another project, however i don't know the pinout, well i could easily find the Vcc with voltmeter. I just need to know which pin will switch on the unit, and if it's a "connect to Vcc" or "connect to ground" system.
Here some more
ref. SADP-220AF (A1200)
24v@4A and 12V@10,3A
A few pics
Cheers!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 7개
선택된 답변
Quick feedback on my tests during the last couple of days
iMac OFF
  1. 0v
  2. 3,3v
  3. 0v
  4. 0v
  5. 0v
  6. 12,1
  7. 12,1
  8. 25,3
iMac ON
  1. 0v
  2. 3,3v
  3. 2,3v
  4. 0v
  5. 0v
  6. 12,1
  7. 12,1
  8. 25,3
PIN-1 & 5 => O volt
PIN-2 => 3,3 volts
PIN-4 => unknown
PIN-6 & 7 => 12 volts
PIN-8 => 24 volts
  • PIN-3 is connected to what seems to be a temperature probe
  • My conclusion is this PSU has no switch ON/OFF,
  • It’s always powered up
  • It's been a few days now i'm using it on both 12/24v, and nothing to report
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Hi, can I use this PSU with M.NT68676.2 and LM240WU2-SLA1 to make external monitor? if yes then how?
This image is of M.NT68676.2A and I have M.NT68676.2, but both looks same.
M.NT68676.2 Inverter Connection Pins
My screen LM240WU2-SLA1's Connection Pins
I want to use Mac's power supply instead of shown in below image:
Can I use it?
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
as long as you power the LCD controller with the right voltage/amperage, you can use any PSU you like,
i personaly use the same setup and it works well :)
I am trying to do the same thing.
I connected my existing power supply, but cannot seem to get the display to function.
There is an output voltage jumper on the LCD control board. Do you leave it at 3.3V, or set it to 5V or 12V?
thanks.
Yes, you can use the original iMac power supply. I have done this. But with some hassles. You really have a new question here, but the longer answer is to order the board with the correct firmware and cable set for your panel. Then connect the cables as follows: iMac pin 4 to four black wires going to inverter. iMac pin 8 to four red wires going to inverter. iMac pins 1 and 5 soldered to the two black wires going to the controller, and iMac pins 6 and 7 soldered to the red wires going to the controller.
The hassle was that I never got the LM240WU2(SL)(A1) panel to work properly. It worked for 1 second, and then washed out into a barely visible white picture. I also have a iMac A1225 with the LM240WU2(SL)(B4) panel, and in desperation I tried that panel. It worked just fine, and the original (SL)(A1) worked just fine in the A1225, so I swapped them. The newer panel looks better anyway.
댓글 달기
Answer 1:
You need just one +12V pin and one 0V or Ground pin that’s it.
Answer 2:
I think you need to use the power supply of the Mac to hook up the inverter.
Answer 3:
As long as the voltages match up and the amperage is equal or greater you are good to go. For example, if you need 12V 2A then you need to supply 12V and at least 2A, you could use 12V 4A if you wanted and it will still work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I managed to get it working on the first try with a late 2006 24-inch imac and a newer controller board that supports display port. Thanks to those who paved the way, using the original power supply.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Good night! Do you remember if you did "iMac pin 4 to four black wires going to inverter. iMac pin 8 to four red wires going to inverter. iMac pins 1 and 5 soldered to the two black wires going to the controller, and iMac pins 6 and 7 soldered to the red wires going to the controller" or can someone confirm that this is correct? Thanks 🙏🏼
댓글 달기
Hello!
Can anyone confirm if this is correct? "iMac pin 4 to four black wires going to inverter. iMac pin 8 to four red wires going to inverter. iMac pins 1 and 5 soldered to the two black wires going to the controller, and iMac pins 6 and 7 soldered to the red wires going to the controller"
Thanks 🙏🏼
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Noooooooo.
Imac 1 and 5 (they are the same) one to two black wires to the controller, and other to four black wires going to inverter.(Negative)
iMac pin 8 to four red wires going to inverter OK. (+24v.)
iMac pins 6 and 7 to the red wires going to the controller OK. (+12v.)
Forget all other pins.
Ive just do it, and works well. The wires that came to me are very thin, you are doing well using all red and black wires.( Please dont use only one.)
I plan to put the card (video conectors) coming out from the ram slot.
And the buttons to the rear side, cutting "in line" all the imac´s outs.
There are colored caps to enlarge the buttons.
Thanks to all for the info.
Have a nice day.
Thank you very much for the reply. I will do it the way you tell me, but in reality, pin 4, being 0V like pins 1 and 5, should also work in the other way that I said above, right?
Good idea how to place it.
Best regards
Hi, ihadadream put: PIN-4 => unknown. ( It was a volt test measure)
Many parts of a circuit can be 0v sometimes but that dont mean they are connected to GND(-negative).
You can see clear in the photo that pins 1 and 5 are connected together with a big track. I cant test now pin4. Dont use it.
Thanks for the clarification! Another question, do you know the pinout of the speakers? I have seen that each of the speakers has 4 cables. I found this video (https://www.youtube.com/watch?v=0pkJvtRM...) where they connect them to the LCD control board so that they work through HDMI but the colors on the 2006 model are different. If you can tell me I would appreciate it, best regards!
댓글 달기
I added the image here, it doesn't leave me in the reply to the comment
Update (02/19/24)
*This is the connector, so it forces me to connect it -++- right?
Update (02/21/24)
On an IFIXIT page for the imac 2008 they put this color scheme for the speakers, putting black as positive and it is just the same connector as well. Would it be incorrect?
해당 답변은 도움이 되었습니까?
점수 0
댓글 7개:
There are 2 speakers:
Black(-) and Grey(+) 8Ω
Pink(-) and Brown(+) 8Ω
I had "imagine" this "polarity" as Black is "always" negative.
I put them in pararell (++/-- 4 Ω).The ampli of the card is for 8Ω. Maybe better to connect them in serial(-+-+) doing 16Ω, (less power but more securety if you plan to use them at hight vol).
AAaaa I had use the original power button enlarging the cables and soldering to the button of the card.
And glued the led in the spaeker hole ( with cables).
Soon ill upload photos.
Thanks for the reply. My board says "It's a 4Pin speaker connector, which you can connect to a pair of 4-ohm 3W or 5W LCD universal speakers" so I don't know if it will be enough or I will need a separate amplifier. I'll try it and post the result. Brilliant! I would like to see that too haha
No. For example: left Channel:
L-(connector) to Black(-).
Gray(+) and Violet(-) together( to "nothing"),
and Brown(+) to L+ (connector).
Or you can connect only 1 speaker for each channel. Choose the same colors, Black(-) and Grey(+), for example.
Could be correct, and sure will work. I think the polarity is not critical in this case of low power. This is the parallel way.
Mine is working too.
댓글 2개 더보기
댓글 달기
이미지 내용 보기:
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
If you put the connector of the buttons in this way, you must invert the cables position.
Nice job 👏🏻👏🏻 I have a question regarding the speakers, do you know what color combination the bass and tweeter are? I'm going to try using a crossover to improve the sound
I dont find info about 2 way speakers. Are you sure? They seems to me equals.
I made all the connections today and it worked. Thanks for the help and for answering all the questions. The only thing is that made a loud hum when the screen was on (showing image). Is that normal? (In the end I didn't connect the speakers because I realized one was broken). It's something a little scary. Before disassembling the imac, when I was using mac os x lion, the screen didn't make any noise.
댓글 달기
귀하의 답변을 추가하세요
ihadadream 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 106
전체 시간: 4,788
