주요 콘텐츠로 건너뛰기
Apple의 MacBook Air 13" 2015년 5월 업데이트에는 5 세대 Intel Core i5 및 i7 프로세서가 성능과 배터리 수명을 약간 향상시켰습니다.
623 질문 전체 보기
Dispaly Backlight Not working
I have Macbook Air 13" Early 2015 model. For few weeks display brightness was inconsistent and keeps flickering. I thought this might be due to Ambient sensor and I turned it off. After some days the display backlight went off and comes back if I adjust the screen.
Now the backlight never comes back except only once when I press at both top corners of screen .
The store people ask me replace the entire screen which cost around 45K INR . This is costly for me to afford at this point.
Kindly help me if there is anything which I can fix .
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If you buy a broken lcd and take it apart and take the back light out and switch them it should fix your issue if it does not your lcd is shorted out and you just need to sell it on eBay.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
LCD shorted ? I can see the display when I light through Apple logo.
Ok then your led backlight needs replaced so if you buy a broken lcd then take the led backlight out but buy a shattered screen that still has a working back light.
댓글 달기
귀하의 답변을 추가하세요
Athavan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 892
