주요 콘텐츠로 건너뛰기
Released June 2014, identified by model number B051.
33 질문 전체 보기
left side speaker not working properly.
It works perfectly fine if the jack is connected. but the left side of the headphone doesn't work while using on wireless.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
So, what i did was, plug the audio cable in WHILE bluetooth was still on, and then took out the cable, turned off bluetooth, turned it on then reconnected 8t
Had the same issue.
This solution worked for me!!
Thank you!!
It works, but why does this work and is this permanant?
댓글 달기
답변 2개
선택된 답변
Hi @hanamichhi ,
Does the BT audio cut out when you insert the aux. cable? (the other end of the cable doesn't have to be connected to anything). If so I'm wondering if you might have a faulty aux. input socket or the wiring connected to it
The wiring circuit in a lot of BT speakers, headphones etc. is that the audio from the BT goes through contacts in the aux. input socket to the amp/speakers, which changeover the audio source from the BT to the aux socket when the plug is inserted.
To find out you'll have to open the headphones where the aux socket is and inspect it. The left earphone is connected to the 'tip' connector (and its' associated contacts of the aux socket) Just a thought.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
@hanamichhi akashshrestha30 , Try this, Go to System Preferences > Sound > Output > Balance ( Set the balance at the middle ), info from link below. If still no improvement perhaps try resetting(link #2) resetting and trouble shooting. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://answers.yahoo.com/question/index...
https://www.beatsbydre.com/ca/support/ho...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
귀하의 답변을 추가하세요
akashshrestha30 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 42
전체 시간: 39,320
