주요 콘텐츠로 건너뛰기
Samsung Galaxy Note 4는 2014년 10월에 출시된 셀룰러 스마트폰입니다. Galaxy Note 4 모델 번호는 SM-N910, SM-N910A, SM-N910T, SM-N910V 또는 미국 버전은 SM-N910R4입니다.
256 질문 전체 보기
Replace digitizer from another Note 4 (not replacement kit)?
Is it possible to swap out the digitizer from another Note 4 in to my own device, without doing damage to the S pen functionality?
When you pry open the screen you apparently damage the copper film -- what is the purpose of this film, and does it damage S pen functionality?
The replacement screen kit everywhere I look is the same price as a used Note 4, or Chinese phone, so the only cost effective option is to buy a broken (for parts) device on eBay that has a working screen.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
I've done it before without any problems. Also, I think you're talking about the contact point for the digitizer on the glass.
As long as you're careful you should be fine. I frequently swap parts of devices. The only times I've had problems were my fault i.e. rushing, being careless, ect.
Good luck.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Have same problem here. OLED is apparently fine but the digitizer is glitchy.
I did also find a crack in the top which *may* be why it had issues but can’t tell for sure until its completely removed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'm wondering the same. And John or Andre did you try this? And if so, can you share the outcome please. Thank you much.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
John 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 450
