주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
No video signals by the ps4's hdmi port
Guys my ps4 doesn't send video signals but it turns on perfectly and i already inspected the hdmi cable and monitor's hdmi port. Now i'm pretty sure the problem is the ps4's hdmi port so i want to know if i can order a hdmi and replace it by myself ( if you comment with a link ).
Thanks for reading this anyway
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
It sounds like you probably have an HDMI port problem. It could also be the HDMI ic chip but that is not as common. While I rarely recommend the average consumer tries this fix themselves I'll link my repair video below so you can decide for yourself. Here's the link:
https://www.youtube.com/watch?v=piwGOaVP...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Did u fix the problem yet? Says solved jy i cant see whats solved here
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Most likely it will need an HDMI port or the ic chip. The emi filters can go bad as well , components and traces need to be tested for continuity. Here is a picture of these components https://asappcfix.com/pix/emi.jpg. The ic chip and emi filters are located on the opposite side of the motherboard under the heat shield. You will need about 480 to 500 degrees Celsius to remove the shield. Here is a photo of that as well https://asappcfix.com/pix/emi-s.jpg. If you are not up to the repair, visit https://WWW.ASAPPCFIX.COM/PS4.HTML for professional repair options.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
blake99 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 18
전체 시간: 20,869
