주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides for Android cell phones manufactured by ALCATEL.
Where'd my flashlight button go?
Well, on 4/27/2017 my Alcatel Onetouch had an update, and the onlything I noticed being different was... my flashlight button missing from my quick access panel (swipe down from top) I have searched high and low on my phone and am unable to find it. I'm a night-time jogger and I use my phones light quite often as it's easy for me to have music and my light on without it being a bulky pain in the rear. Anyone got any ideas on how to get it back? I understand I can go with an app from the playstore, the problem with those is.. each one I've tried won't allow me to lock my phone without turning off the light..
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개
I had the update as well and have had the same problem but I have found a solution. If your phone has the Google voice command you can say OK Google turn on flashlight and it will come on and to turn it off you can either hit the off button or say OK Google turn off flashlight. This also allows you to lock your phone while the flashlight still functions
my flashlight stopped working & now Google Assistant says my phone didn't come equipped with a flash when I know I just used 3 nights ago.....I have an Alcatel Tetra
My flashlight isn't on my phone also I don't see it.
Mines doing the same thing
where is my flashlight on my cell phonewhere is my flashlight on my cell phone where is my flash light
댓글 달기
답변 10개
가장 유용한 답변
이 답변이 도움이 되었나요?
점수 2
댓글 달기
The company who wrote the firmware for the update for the phone probably changed the phones ability to use it's flash LED as a flash light. Couldn't tell you why, it might have been a company/device wide standardisation thing, not many androids come with the flashlight feature built in.
Unfortunately, the only real option is an app from the app store.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
댓글 달기
If you figure it out, please let me know. Just updated today and am a little aggravated, especially since I use the light for everything
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
well I tried this & Google Assistant told me that my phone doesn't have flash but an Alcatel tetra lists a dual LED flash & that's what my phone is.......the flash worked earlier
댓글 달기
On my phone it is on the drop-down window.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try this application , you will be satisfied . A useful flashlight app that it has phone temperature display and phone's charge level screen : https://play.google.com/store/apps/detai...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Do my Android alcatel have a flashlight
댓글 달기
just download android app called icon torch, no ads or dependencies
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have the same problem sorry my flashlight just disappeared I also like use it to at night hope you find the answer and post it
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Only way I can use is by going to camera app. Activate flash for photos. Then change from photo mode to video mode. Now flashlight comes on.
댓글 달기
Just replaced my lost phone with an Alcatel 1 and as said above “no light”. Then found you have to swipe down to show volume, wifi, blue tooth. Swipe again and all the normal bits are there including the flash light.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hello Patty,
I'm assuming that you have a Android cellphone. I had the same situation, that you are currently experiencing. These are a few remedies:
1). Open your Google search app. Press the microphone button and say “Google, turn on flashlight”. Tada! Your flashlight has now turned itself on (to turn flashlight off, repeat previous steps and then say “Google, turn off flashlight”.
2). Open your phone's camera app. Set it as if you were going to make a video. Then activate the camera's flash. The flashlight will turn on.
3). Back up entire settings and preferences on your4 cellphone and then perform a complete factory reset (This is the option I ultimately had to do).
Good luck… Kevin
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If the flashlight doesn't appear after swiping down twice, press edit and move the flashlight icon up. You may have delete an icon first - only 7 are allowed at a time.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
matthew.jarrett88 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 14
전체 시간: 19,269
