주요 콘텐츠로 건너뛰기
Updated version of the original iPad 2, released in March of 2012 with a smaller die processor and updated internal construction. Repair will require the use of heat and careful prying.
73 질문 전체 보기
Ipad 2 Wifi turns itself off after battery replacement
Hi, I recently did an Ipad 2 Wifi Digitizer and battery replacement. Initially it seemed everything was working fine, but after 2 or 3 minutes of being powered on it turns itself off. Initially I thought it might have a loose connection to the battery but that is definitely not the case, the board is screwed down ontop of the connector and it restarts just sitting by itself.
Has anyone else seen this before? I ordered a new battery in case this one is defective, can't test it with the original battery because it was damaged during the removal. I'm wondering if the OS forces it to shut off when the battery percentage increases or decreases. The battery does charge up and arrived at 28% and I charged it to around 33% while messing with it. Now I have it manually turned off and charging so it won't force restart itself while plugged in.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
You could have a defective battery, there are lot's of low quality ones on the market. Certainly install the new one when you get it.
It could also be the charging circuit. However, before we go there, I would inspect the ferrite bead (FL7500, the one on the bottom left is the red square). It is inline with the charge state going back to the charge circuit. It may have been damaged when you played around the connector area. If you have a multimeter, measure it to see if it is a dead short (it should be).
Then get back to us with your findings.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
That's what I'm telling my techs. Try to scoop the connector, not pry it up
Thanks for the super fast response. At this point I believe it is just a defective battery. I had it on and watching the battery indicator, it was at 46% then shut off when it should have changed to 45. When it came back on it was at 32%. And this Ipad doesn't look like the one in your picture, there are EMI shields completely surrounding the LCD connector except for a line of compenents at its rear, and there's a connector at the end of the board not the side of it. If I filed this question under the wrong device I apologize. Model A1395
댓글 달기
귀하의 답변을 추가하세요
Colin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 149
