2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
3323 질문 전체 보기
Front Panel itself has separated into two?
I had a swollen battery with this phone and I replaced it with one of iFixIt's replacement batteries. However, as I was putting the screen back on, it seems that the whole part separated into two items of their own. A part that is primarily glass, and the rest which is the silver part we can see if we look at the part from the back.
Did I permanently damage my screen? It doesn't work now. Perhaps some of the cables at the top got moved and something got out of place?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
It depends how you took out the screen when you first opened it.
When it comes to swollen batteries that pushed the screen up separating the glass from the screen frame I always run a razor blade on the side between the iPhone housing and screen frame gap to pop up the screen from the sides when I lift up the screen because when a suction cup is used it's almost guaranteed the screen will get damaged as the cables coming from the screen would be very loose from the frame.
Has the phone been repaired before? Maybe perhaps the metal plate that goes on top of the screen connectors were missing if it was repaired before?
Most you can do is try replugging the screen connectors and checking for any dust on them otherwise it's going to need the screen to be replaced (after all the screen has already separated completely from the screen frame and does not work anymore).
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Thank you for replying. The phone has not been repaired before. The cables seem intact, but I guess it's something my untrained eye can't see. I will most likely replace the screen, thank you. :)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
TiTravameKaiDenToMartirame 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 30
