주요 콘텐츠로 건너뛰기
Repair guides and support for Gigabyte laptops produced since May 2003.
24 질문 전체 보기
crashedgigabyte notebook's imminent and necessary revival
my Gigabyte notebook just shutdown by itself a few months ago and am now planning to open it and take a look inside to see if maybe I can get it to start up again, so I needed some advise on how to go about the repairing procedure before I start.
Are there any vital aspects I should take in mind when conducting the repair, and if possible are there any tips to assist me with my problem?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
What is your laptop model? Also, tell all the details you can remember before it shut down.
댓글 달기
답변 1개
가장 유용한 답변
did you try to start it up again after giving it some time to cool down?...my guess is "the cpu cooling heat sink fins are blocked by a mix of hair\lint\dust" so you'll need to tear it down and clean it properly then reassemble it back again and attach it to the cpu using a fresh new thermal paste...don't put too much just use a thin lines shaped as X shape on top of your cpu.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Marc Chisanga 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 51
