Can I run an iMac headless?
I have an early 2009 2.9GHz 24" iMac with an NVIDIA GeForce GT 130 512 MB that is real close to dying. If I can find a replacement, it will cost way too much for this old of an iMac. I'd still like to try and run OS X Server (10.11-max) and know the Mac mini can run headless when configured properly. If I disconnect the graphics card, will the iMac still start up? With it running OS X Server, I can remotely connect to it and use it as a media server or something else.
Thanks
I just ordered a used late 2015 iMac to replace it before it doesn't work anymore. The screen starts fragmenting, gets real fragmented, then locks up.
좋은 질문 입니까?
댓글 3개
Try it, if it doesn't boot then there is obviously a problem. Set Automator to make a noise when it starts up and then remove the card and see if you hear the sound after a while.
Gigabit87898 의
I might try removing the card and see what happens but I was hoping someone has tried it before.
plink53 의
I am running a late 2009 27" iMac with a bad video card. I just unplugged the screen. Control it through screen sharing.
fxsrider 의
