주요 콘텐츠로 건너뛰기
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
448 질문 전체 보기
Which kind of digitizer connector on the LCD/Digitizer set
I have an unusal fix to perform actually.
It's on an Ipad Air 2, but in fact it's not located on the mainboard but... on an LCD/Digitizer set. The set is in good condition but on the digitizer ribon the two connectors (one 42 pin & one 34 pin) need to be replaced as some pin are spoiled.
I can change them but the only issue is that I can't find these connectors to buy.
Can somebody tell me if it is possible to find them somewhere?
They look like this : http://www.mobilemates.com/M-SPiP5-1053_...
Thanks
I
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This is gonna be pretty difficult to find. Your best bet, is to find another repair shop, that has one with a broken LCD. Then you could source the parts you need. Pretty uncommon for folks to repair the connector socket cables
해당 답변은 도움이 되었습니까?
점수 4
댓글 4개:
The OP would have to spend some time on sites like Digikey and look for one that has the same physical specifications. Hirose is another common manufacturer used for these types of connections.
Thanks a lot Minho for this usefull info. I just bookmarked the site :)
iMedic : yes pretty uncommon I agree. But admit that when it is located on a set that usualy cost 120/130 $ pce this solution is not an option.
This is why I raid the graveyard
댓글 달기
귀하의 답변을 추가하세요
Patrice 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 89
