주요 콘텐츠로 건너뛰기
The Canon PowerShot SX160 IS is a 16.0 megapixel digital camera with a 16x wide-angle optical image zoom and a 3.0 inch LCD.
25 질문 전체 보기
Display of message that says 'change the batteries'
My camera keeps displaying a message that says 'change the batteries'. Why is this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@tyiilliamani, Kenzo , Ensure that the battery contacts are clean and install a new quality set of fully charged batteries and if using rechargeable's have charger tested or try another known good working compatible charger to rule it out as an issue. Possible internal clock battery may be faulty (change internal CR1220 battery) or issue with bad components in camera. Find below links to showing the internal clock battery replacement and partial disassembly guide to enable checking of internal wire connections/components/etc. to check for loose, damage, burnt. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Canon PowerShot SX160 IS Clock Battery Replacement
Canon PowerShot SX160 IS Outer Case Replacement
Canon PowerShot SX160 IS Clock Battery 이미지
안내서
난이도:
운영
15 - 30 minutes
Canon PowerShot SX160 IS Outer Case 이미지
안내서
난이도:
운영
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Kenzo 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 22
전체 시간: 3,077
