GPS not working after battery replaced.
Where is the gps connection located?
좋은 질문 입니까?
Check if you didnt disconnect any cable. There is a signal one near the battery connector
해당 답변은 도움이 되었습니까?
Did you take out the logic board? The antenna contacts to the iPhone housing are held in by two phillips head screws that screw into the iPhone's housing at the top of the logic board.
Either you need to put the screws back on there or replace the antenna (Usually gets ripped when not taking the two screws out and pulling out logic board) which is not an easy thing to do as shown here:
https://www.youtube.com/watch?v=Q3gw1KDW...
Also shown here on step 25:
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,443
