주요 콘텐츠로 건너뛰기
Easy to use camera for children, able to be mounted on bikes, skateboards, helmets, etc..
6 질문 전체 보기
What are the specifications or model of the replacement battery?
The description of the removal of the old battery is good, but I would want to have the replacement available before removing the old one. What kind of battery would be the appropriate battery for replacing this?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
Hi,
It is a Lithium Ion (Li-Ion) Polymer type battery.
It should have the Voltage, Current rating and dimensions information printed on the battery itself.
Unfortunately the ifixit repair guide for the battery removal for the camera does not show the specifications clearly.
It may say something, (and this is only an example) such as 3.7V 250mAH 502030.
The 502030 is a format convention used to describe battery dimensioning. It means that the battery is 5.0mm thick x 20mm long x 30 mm wide. The first 2 digits are always the thickness (or depth) of the battery (note the decimal point is used. It is not used for length and width), the next 2 are the length, and the last 2 are the width. Obviously sometimes when the length or width exceeds 100mm it will be 3 digits etc
You would need to open the camera and view what is printed on the battery and then use the information to search such sites as Ebay, Alibaba etc to find suppliers of the part. If you cannot find an exact replacement, as long as you get the Voltage (V) and Current (I) values correct and the battery will physically fit into the camera you may find a battery that is physically slightly smaller but has the same V/I characteristics (or even close as far as the Current goes) that will suffice. Ensure however that the Voltage specification (whatever it is) is exactly the same
Hopefully this is of some help
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
tpert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 5
전체 시간: 300
