주요 콘텐츠로 건너뛰기
Galaxy S7 Edge는 Samsung의 2016년 주력 휴대폰 Galaxy S7의 곡선형-스크린 버전입니다. 2016년 2월에 발표되었으며 3월 11일에 출시되었습니다. 모델 SM-G935.
331 질문 전체 보기
My Samsung isn't charging.
Hello!
I got a pretty strange problem with my s7 edge for few days:
I am unable to charge it using my fast charger, because it can't be detected. I can charge it using an external battery though, which i charge with the same charger.
Any ideas about my issue?
P.S: my cable is a bit damaged but i think this might not be the problem as long as it does function on my external battery, right?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글:
aka.aleex, Get your self a new compatible cable to eliminate that as a problem, especially if it is showing any sign of damage.
but it is charging my battery, and i can charge the phone via pc aswel. at first, i thought it's a software error
I want to gift my Samsung 7 but it's not charging!
의견 추가하세요
답변 4개
선택된 해법
Make sure you use the original power adapter and USB cable because if not, that might be the reason why your phone isn’t charging at all. Remember, a battery as huge as the S7 Edge’s need a powerful charger and considering it’s capable of fast-charging, you need something that’s specifically designed for such feature.
Check both ends of the cable for corrosion, debris and/or lint. Anything that goes between the receptors in the phone and the pins in the cable may interfere with the normal charging process. Be also on the lookout for bent or crooked pins. If you can find one, try straightening it out.
Inspect the port on the power adapter. Try to see if there is corrosion of some kind or bent pins. You also need to check the USB or utility port on your phone for the same thing.
Assuming there is nothing that blocks or corrodes the pins, try turning off your phone and plug the charger in to see how the phone reacts. If it shows the usual charging symbol or lights up the LED indicator, then the charger is ok as well as the cable. However, if the phone doesn’t respond, then it might be an issue with the adapter or the cable and to rule out these possibilities, you need to use a different charger. If the phone charges fine with other chargers, then you need to buy a new charger kit, otherwise, continue troubleshooting.
If the phone won’t respond when plugged in, it might be a simple system crash issue.
Perform the forced reboot procedure by pressing and holding both the Volume Down and Power keys together for 7 to 10 seconds. The phone either reboots or the screen flickers for short time. You can then try charging your device and see if it responds this time.
Boot your phone in recovery mode if it still didn’t respond when you plugged it in. In Android System Recovery, all necessary hardware are powered up but the Android GUI isn’t loaded. So, if it’s not a hardware issue, your phone should be able to boot up in recovery mode: press and hold the Home, Volume Up and Power keys together.
If the phone won’t boot up in recovery, it’s time to have it replaced because it might be a hardware problem. However, if it started fine, then try wiping the cache partition. If that didn’t make any difference, then try doing the reset still through recovery mode. In case the phone remained off (and didn’t even flicker), there’s a chance the battery was all drained and since the device won’t charge, seek help from a technician.
해당 답변은 도움이 되었습니까?
점수 5
댓글:
The cord works with charging up the fast charger, just not when hooked to the fast charger to charge the S7edge. Phone charged fine with auto charger and wall charger (not the Samsung one issued with phone.)
i have a Samsung galaxy s7. and for a week now, i haven't been able to charge it using the original charger. or any other charger. It sometimes will charge a second. then stop. one time it said moisture has been detected. but i did not get it wet. And i haven't been able to charge it. how can i fix this?
의견 추가하세요
I think I have solved the charging problem with the Samsung s7. I would stop at 53% and go no father. I allow it to discharge to 0%. The I charged it again and this time it stopped at 73%. Then discharged it to 0% again. And recharged it again, and this time it went to 100%. It seems like that the battery need to be exercised up and down to get full activation of the cell in the battery. The old wet cell batteries would sulfate and act this same way.
(plates would become hard and not be able to accept the electrolyte).
Don't know if this is the case but it fixed my problem with the phone not being able to reach 100% charge.
Don R
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
Argmhgdfzgjjtusktudytskiyst
Update (12/12/2018)
87fyuyfuoydoudtcghiuitdcuygictyidgydtycfyidfyi87rtiglcgcj,
해당 답변은 도움이 되었습니까?
점수 -1
의견 추가하세요
be a iphone user brother
해당 답변은 도움이 되었습니까?
점수 -1
의견 추가하세요
귀하의 답변을 추가하십시오
aka.aleex 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 11
7일 전: 112
30일 전: 549
전체 시간: 79,899
