주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
iPhone 5 Wireless Charging?
Hello Everyone, I found an idea about wireless charging. I Want to attach built in wireless pad into my iphone but i have some problems about it. First of all pinouts, Which pins i have to use it on lighting charge flex ? Secondly, What happens if i want to charge with cable ? Thirdly,is it overheat my phone ? Thanks for replies.
PS: It was working on 30 pin iPhone 4s.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@naokotakeuchi, Hakan Er, Just a thought, you may best to contact the maker of the built in wireless pad to confirm if it can be used in the iPhone 5 and see if they have schematic/install instruction. Below are a couple links for you to check out to enable wireless charging of iPhone 5. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.macworld.co.uk/how-to/iphone/...
http://www.todaysiphone.com/2013/12/wire...
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
This links are all External Wireless Chargers, I need to do it internal. Soldering wireless charger to lightning port. Thats what i want. Example; https://www.youtube.com/watch?v=i7WDQz6v...
Hakan Er, That is a very cool charging system modification, sorry could not help more. The question will remain open for other volunteers to give there answers also if able. Good luck on your iPhone 5 mod.
댓글 달기
귀하의 답변을 추가하세요
Hakan Er 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 138
