Getting hot and loosing charge
iPhone 5 keeps getting hot when on charge also battery drains quickly evern when switched off.
좋은 질문 입니까?
좋은 질문 입니까?
It sounds like your battery is going bad. This was a problem with many iPhone 5 phones.
Below are the guide for the removal and replacement and the actual part you need.
해당 답변은 도움이 되었습니까?
Thanks for the reply,
I have tried a new battery already still the same, the phone all works as it should but heats up and really quick battery drain.
Then you might have a short on your motherboard. A new phone might be the best option for you at this point.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 70
댓글 4개
What part of the phone is heating up? Battery? Rear camera?
Gigabit87898 의
Quite hard to tell without some more info. From what youve posted, its sounds like a battery issue. is it bulged at all?
Eric 의
No battery isn't bulged and the heat seams to be coming from around the SIM card area on the back of the phone.
Lee 의
Also the phone was 100% charged and switched on it also wasn't connected to the charger and still was warm the battery lasted about 5 hours then has turned off. The phone has also been totally reset using dfu mode. Saying that though I am sure if the phone is left on the white hello screen it behaves a lot better it's only when you have gone through setup and it's on the app screen.
Lee 의
