주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4847 질문 전체 보기
Why won't my iPhone turn on?
Around a year ago I smashed my first iPhone so I took it to a store to be repaired, afterwards it was working fine but then the screen started to come up but it went down when pushed back in, it then started to have charging problems and wouldn't turn on at all, I really need it to work if possible, last resort I buy a new phone... thank you.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Is the phone recognised by a computer when plugged in? iTunes should pop up and say something.
의 답변
Let me try. :)
의 답변
Okay, I tried my iPod which is working and it showed up on iTunes but when I tried the iPhone it didn't...
의 답변
의견 추가하세요
2개의 답변
선택된 해법
From your description, it sounds like the battery is swelling. That would explain the screen being pushed up and the charging problems. I would open up the device and take a look. If the battery looks like a bag of chips, then it definitely needs replacing.
To be certain, use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows). It will tell you what the health of the battery is. Anything less than 80% of design capacity will require replacement.
Be wary of cheap replacement batteries and order from a reputable vendor. Take a look at this guide to see what is involved before attempting this repair yourself.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
Have you tried the basics 1st? Try cleaning out the charging socket in the bottom of the phone they can get fluff, dirt, bits etc stuck in the bottom which stops the charging plug going all the way in.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
How do I do that? Thank you. :)
의 답변
I have done this with the SIM card tool, pop the sharp end down the socket and pick at the bottom and see if any bits come out does the plug snap in and sit nice and flush on the bottom of the phone.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Laz 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 50
