주요 콘텐츠로 건너뛰기
2.3L 4cyl or 3.0L V6, 6th Generation
383 질문 전체 보기
Where is the ignition coil?
Hello,
I think I might have the case of misfiring for my Honda Accord 4 cyclinders LX. My plan is to change out the ignition coil; yet I'm unsure of its position.
If any of you guru could help me in pinpointing out where it is, that would be great.
Sincerely.
Update (05/26/2017)
1999 Honda Accord LX 4 cyclinders.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
Skip the upgrade.
Take $10 off $50 with
SKIPANDSAVE10
Save Now
Skip the upgrade.
SKIPANDSAVE10
Save Now
2개의 답변
선택된 해법
your coil, pn 30500-PAA-A01, is located inside the distributor, under the cap.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
Before going to the expense of replacing the coil it may be a good idea to get the codes read and find out for sure what the problem is .A misfire is not usually cause by a coil unless you have individual coils . This is an excellent video for diagnosing misfires in a honda
https://www.youtube.com/watch?v=m2fubKkv...
Hope this helps
해당 답변은 도움이 되었습니까?
점수 3
댓글:
I agree with Jim, do not replace coil prior to other checks for misfire, Good diagnosing video link above in his answer.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Hien Nguyen 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 39
지난 30일: 203
전체 시간: 4,943
