메인 콘텐츠로 스킵하기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
636 질문 전체 보기
Why wont my van run in drive but will run in park
I have a 2001 chrysler van we just replaced my catalytic due to clogging now my cat gets red hot and exhaust makes popping noise also runs in neutral but when i switch to drive and try to touch gas stalls immediately im guessing o2 sensor or map but i dont wanna spend the money if thats not the problem any ideas?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
가장 유용한 답변
@alpow1882, Amanda, Check to see if you have any vacuum lines disconnected or possible vacuum leaks(links below may help). If able to have the vehicle scanned for engine trouble codes as this could help diagnose/lead to the failing sensor/part. Some of the auto parts suppliers offer free code reading like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=9CPqbaSg...
http://www.aa1car.com/library/vacleak.ht...
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Amanda Powell 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 14
