TV has black screen
I have back tore off where do I look and where do I get parts
좋은 질문 입니까?
@jaxsn30 as I pointed out in my comment we need more information. Post some images of your boards with your question. That way we can see what you see. Use this guide 기존 질문에 이미지 추가하기 for that. You do want to check if it is the backlight or the T-con board/power board. In a dark room turn your TV on and switch it to a known good station (or if you know how to set your menu that will work as well). Take a flashlight and at an angle shine it on the screen and see if you can see any movement. If you do, you will know that you have a failed backlight. If you do not it is possible a T-con board or power board failure.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,442
댓글 2개
@jaxsn30 we need way more information. No picture but sound? What have you checked? Did this just start? Anything happen to the TV prior to this?
oldturkey03 의
thanks I will do things and get back to you
Matthew jackson 의
