주요 콘텐츠로 건너뛰기
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
139 질문 전체 보기
Why won't the arm that raises and lowers the deck raise or lower?
No spring action in arm. Was cutting grass, stopped, went to raise arm and nothing. Stuck down and won't cut grass.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
This could be a result of a connection somewhere that broke loose like the lift links not being connected. If you could give me a model number of the mower I could maybe find a diagram to help you find those lift link and connections.
해당 답변은 도움이 되었습니까?
점수 0
댓글 4개:
Hey Justin, i'm having the exact same issue with my Murray. Is it possible that you can find me a diagram of the lift links or springs that connect to the arm to raise and lower the deck? Model Number 42516X92B/skynz71@yahoo.com
Having the same problem with my cub cadet 1420. Could you possibly find a diagram for it? Thanks
I have a husqvarna GTH2654 the deck won't raise or lower either.
I'm having the same issues for a Ferris zero turn 52 in deck
댓글 달기
The front end of the deck that connects to the rod wont raise on my troy-bilt hydro
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Lifting arm will not raise mower deck on XT1 w/ 46” deck?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
tanyafaucett 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 43
30일 전: 117
전체 시간: 6,403
