Kickstand welded and will not budge
I have never seen a kickstand that was welded to the frame. Once down it will not return to the up position. I have no idea what to do.
좋은 질문 입니까?
좋은 질문 입니까?
@eddiem, Eddie, You may be able to lube(oil) the hinge/spring area of the kickstand to get it moving more freely if stuck. You are right, it is unusual for a kickstand to be welded to the frame of bike. If all else fails the kickstands weld may be able to be cut/ground off with a angle grinder and then stand can be replaced with a new one. If not comfortable/wanting to remove the stand your self perhaps pop into a local auto repair/autobody shop and have them remove the welded on stand for what I would think would be a small fee. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 670
댓글 2개
Could you please take some nice pictures?
기존 질문에 이미지 추가하기
George A. 의
are you sure theres not some sort of safety clip to keep it from releasing when you don't want it to
Jimfixer 의
