주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3935 질문 전체 보기
Home button loose after screen replacement
I had my iPhone 5s front panel assembly replaced because of glass damage and now the home button rocks in it's place. Seems like there may be a gasket or seal missing now. I have done a ton of googling and I can't seem to visually identify what might be missing from the home button assembly.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
2개의 답변
가장 유용한 답변
@efb115,Erik, Home button rocks. This could be because of bad/missing gasket or the button bracket not installed correctly. Below are links for replacement parts(bracket 1st link, gasket 2nd link) and also guides/vids to help open the device to check and make repair. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
iPhone 5s/SE Home Button Bracket
https://www.fixez.com/iphone-5s-home-but...
iPhone 5s Home Button Replacement
https://www.youtube.com/watch?v=2NZgucac...
https://www.youtube.com/watch?v=SD_6oVXX...
iPhone 5s/SE Home Button Bracket 이미지
상품
$5.99
해당 답변은 도움이 되었습니까?
점수 4
댓글:
Yeah, the first thing I did was remove and reassemble the home button assembly and that didn't fix it. That black gasket is still there, but is there another adhesive pad or ring that goes between plastic button and the button sensor on the cable?
의 답변
Erik Brandt, By the looks of the 1st and 2nd video link provided, the replacement gasket should have adhesive on both sides perhaps, the vids. show all parts used when install of home button.
의 답변
The adhesive on the black home button rubber gasket has weakened / separated (probably on the old screen).
To fix this issue you will need to actually replace the current rubber home button gasket with a new one which will have adhesive on it.
I generally buy the iPhone 5s home button rubber gasket from eBay myself.
의 답변
의견 추가하세요
It is also possible that the aftermarket screen have a button hole that's is slightly larger than original screen.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Erik Brandt 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 13
지난 7일: 82
지난 30일: 406
전체 시간: 17,516
