My phone is not charging and is stuck on 1%
my iphone se is not charging and it stays stuck at 1% battery with the charger pluged.
when i remove the charger it stays on for 20 seconds, but it's moving verry verry slow, it s like the battery not giving enough power.. after the phone shuts off, is trying to turn on by himself, apearing the apple logo and disapearing until probably drains all the remaining battery..
when i plug the charge, the apple logo apears and disapears couple of times and after 2-3 minutes the operating system starts normaly with the 1% battery(probably the battery is charging a little bit).
there are times when the phone starts with 100% battery but when i remove the charger, the same problem, it s shuting down after 20 seconds
the battery is new, but it s an aftermarket.. could it be something else beside the battery?
좋은 질문 입니까?
댓글 3개
I’m having sorta the same problem, but mine is stuck at one percent but dosent die when it’s off the charger, I plug it in and it still says 1% no matter how long I leave it, but it also dosent die off the charger
Wolfie Christensen 의
I just recently bought a new charger because my other one was not working and it would stay on one percent but say its charging. I have tried moving it to different outlets and the same thing would happen. Now it's dead and wont come on. It was dead last night so I went to sleep and it got on 100 percent the night before. But the battery will just not go up. Can someone please explain what's wrong?
Dixie Wilkes 의
It's the battery and it can be killed if you often use your phone while charging .
Brenda Garcia 의
