주요 콘텐츠로 건너뛰기
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48 질문 전체 보기
My computer has a black screen, wont turn on
My computer is 2 1/2 years old. I got the black screen about a month ago. Took it in and they replaced the battery. That lasted a week and now it is black again!!! Very frustrated with the Toshiba product. What do I do!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
twcarlson53 when you say it has a black screen, does the rest work properly? what exactly is going on with your computer? What does or does it not do?
댓글 달기
답변 1개
가장 유용한 답변
Hey Carlson,
When you say black screen, does the laptop turn on, are the fans spinning, are there any LED indication lights on? If so, let's do some troubleshooting, connect your laptop to an external monitor, if the monitor displays it might be your screen that is faulty. Try removing and or replacing one memory module and see if that boots up. Also try cleaning it, dust may also cause a laptop not to switch on. Try turning it on while plugged in and the battery is out.
Hope this helps
Ewald
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
twcarlson53 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 731
