주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
My iPhone not turning on (because the update is interrupted)
Im updating my phone Iphone 5s to be exact when the internet suddenly disconnect (No more wifi connection ) my phone suddenly turns off and not turning on what could be the possible deffect ?
I cant restore it on itunes .
Is this already a dead board ?
How can i fix this thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Connect your device to your computer, and then launch iTunes of 3uTools to see what mode your device is in.
If it is in DFU mode or recovery mode, just easy flash your device to enter Normal mode.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
I've never seen a case of this before.
The way iDevices work is that it first downloads the software, disconnects from the Internet, then applies the update.
I would first download the iPhone firmware on a computer with iTunes from
http://www.iclarified.com/750/where-to-d...
remember where you downloaded it
Then plug your phone into the computer and put your phone into DFU mode.
There will be a message if done properly that you need to restore your iphone.
On a Mac hold Option on the keyboard, and click Restore. Then choose the firmware you downloaded.
On a PC, hold the SHIFT on the keyboard, and click Restore. Then choose the firmware you downloaded.
If this does not fix your issue, you do have a non related hardware problem. This will require different troubleshooting methods.
해당 답변은 도움이 되었습니까?
점수 2
댓글 7개:
What should i download the firmware that im installing or my previous firmware ?
Download the latest one (I think its 10.3.2).
Okay thanks :)
Is their any possibility that the board is broken due to the failed updating of the phone ?
Not from a software update.
댓글 2개 더보기
댓글 달기
You could try entering DFU mode if none of the solutions above work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Fixie 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 186
