주요 콘텐츠로 건너뛰기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
265 질문 전체 보기
Ports on right side of the laptop doesn’t work & wifi not detected
13” Mac pro late 2012 (model A1425)
Drop off from 1.5 feet onto the carpet in flat position
no scratches or appearance damage occur.
But it effect
1. airport module is not detected (wifi no hardware installed error)
2. USB, HDMI & SD card slot on right side of the laptop doesn’t work
I have removed the airport card and installed it again but hardware is still not detected.
I would like to know:
1. It can be fixed only by replacing whole logic board or
2. It could be another minor disconnecting problem* Hit <enter> to insert another list item, and <enter> twice in a row to end the list. To get subitems, repeat the bullet character once for each level of indent you want (e.g. **)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Reseat the I/O cable (which goes from the logic board to the I/O board) and replace this if it is still not working. This commonly goes bad when dropped, and transfers all signals from the side board to the logic board.
Don't replace your logic board; you will have the same issue since it is just the cable :)
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Hi there,
Which one is that cable? I have the same problem but I cant find that cable.
댓글 달기
I was wondering if this worked
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ZebBilly 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 574
