주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
441 질문 전체 보기
Will not charge, no charging light on magsafe?
Hi, I plugged my MacBook into a friends aftermarket power supply, and when i returned home there is no light when plugging it onto a real magsafe charger. Tried using a different charger, resetting SMC.
Also if I plug the magsafe into a different mac and then into mine, the light is orange but slowly goes dimmer until it goes out, and doesn't charge the mac.
이 질문에 답하세요 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
답변 1개
I was having that problem. I had several after market power supplies an very slowly my MacBook Pro stopped charging. I would wiggle the MagSafe a little and the amber light would come on the start charging but it got worse and finally I decided to change out the upper case. I SO didn’t want to pull my Mac apart but I finally did.
Do you know what fixed the issue?? A half hour replacement of the MagSafe DC in Board part. I bought a used one off of Ebay for $8 and used the iFixit Guide and it was all better. The amber light came back on with ALL the after market power supplies I owned. I was SO thankful. Try it. You will see
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Chris 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 3,238
