주요 콘텐츠로 건너뛰기
The Bose SoundLink III, released February 2014, is the 3rd generation of Bose's SoundLink Mobile speakers. It is a modern, minimalist Bluetooth-capable portable speaker.
20 질문 전체 보기
Why won't my speaker won't open or charging
I'm using my Bluetooth speaker, when i went to charge it , It disconnects .when i connect it and try to restart it won't open
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
가장 유용한 답변
1. Make sure your speaker is plugged into a working AC socket.
2. Check the connections between your speaker and the power adaptor.
3. Make sure you are using the power adaptor supplied with your speaker upon purchase.
4. If you are using a surge protector, check to see if it is working properly.
5. If you still cant get your speaker to turn on you may have a faulty power adaptor.
6. If your speaker is not charged or used within a 14 day period it with enter protection mode. Connect the speaker to the AC power adaptor to fix this issue.
7. Make sure the battery has sufficient charge to power on the speaker.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
paulie arana 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,869
