Front windshield washers do not work, but no blown fuse?
How hard is it to replace the windshield washer pump
좋은 질문 입니까?
좋은 질문 입니까?
Have you checked if the pores a are blocked if they are use a cocktail stick to unblock them
해당 답변은 도움이 되었습니까?
You accepted an answer to your question that did not resolve your problems? I thought it was your pump that did not work and needed to be replaced?
This is for the pump replacement. Remove the right front wheel and tire assembly. Remove the right front splash shield.
This info is of course available here http://www.ehow.co.uk/how_6153302_change...
WARNING: Windshield washer solution contains methanol, which is poisonous. Observe all cautions and warnings indicated on the label of the washer solution container. Failure to follow these instructions may result in personal injury.
NOTE: To prevent spilling windshield washer fluid, drain the windshield washer reservoir before removal.
Position the windshield washer reservoir aside.
Remove the bolts.
Remove the windshield washer reservoir.
Disconnect the electrical connectors.
Disconnect the hoses.
CAUTION: Do not operate the windshield washer pump prior to filling the windshield washer reservoir.
There was also a recall listed here http://www.carhelp.com/ford-escape-recal.... Good luck and let us know if that is what you needed or if there was other issues since your question did not quite match the other question :).
해당 답변은 도움이 되었습니까?
if it is your wipers, check out this info re. recall It's old but it shows there have been issues. http://www.msnbc.msn.com/id/10081354/fro...
+ nice research
Still not working. Checked every fuse in the car. 2011 escape. Also changed the pump.
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 19,803
댓글 6개
kevin are you talking about the pump for the windshield washer fluid? What is not working? Your wipers not moving or no fluid coming out of the sprayer?
oldturkey03 의
front wipers work but the front windshield washers do not
kevin 의
do you hear the pump "humming" when you engage the washer fluid?
oldturkey03 의
pulled inner wheel well checked for power at the plug for the washer pump, had power to the plug. pump was bad replaced with a new one. thanks for the input
kevin 의
Glad we could help. Good Luck and all you have to do is accept the answers so that we know that you "case is closed" :)
oldturkey03 의
댓글 1개 더보기
