주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3531 질문 전체 보기
Touchscreen broke after screen replacement
Hi,
Lately I have a lot of problems with the touchscreens of my screens.
If I replace the screens than sometimes there is some ghost touching or the touchscreen doesnt work.
If you unlock it than, it works again.
And this happens with multiple screens.
Am i doing something wrong?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
I cannot stress this enough.
Make sure the iPhone metal housing frame is bent back closest to original condition so that you are not squeezing your screens in causing the digitizer to go faulty.
You can test fit the corners of the housing with the screen by placing the screen flat upside down against the frame.
It has to be easy to install the screen without requiring forcing the screen in.
Make sure iPhone housing is not bent, dented in corners obstructing screen from going in and if you really need to, file / sand off the bottom plastic of the screen a bit to make it easier to fit in due to denting / bends.
Once you see the glass separating from the plastic screen housing frame due to forcing the screen in then I recommend trying another screen because that one may already have gone faulty from forcing the screen into the housing.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
I can only suggest that if your screen broke and your getting ghosting you might need to check your connections or get a better screen. I would suggest the ones sold here. iPhone 5s Screen
I use to try and save money by buying the cheap ones but kept having to hope it worked. With the ifixit units, I have not had that issue. It also has a lifetime warranty that they stand behind. Good luck. Be sure to double check connector and use the repair guides to save some time.
iPhone 5s Screen 이미지
상품
iPhone 5s Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Clean the motherboard connector and try again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Simon 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 88
