주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
5005 질문 전체 보기
iPhone 6 backlight faint after drop
I got myself this iphone for a bit of training on the backlight related problems. Iphone was dropped badly with upper portion of screen smashed. I removed the shield and nothing seems visually out of order. Connector seems in order too.
With phone turned off I'm getting a steady 4.2V all along the line up to the filter and pin2. When phone is turned on, at filter TP I get a steady 14,7V wich seems a bit too much on the low side and might explain the low backlight. Should I turn my attention to U1503 and try replacing it or there are other possible components to be checked and I'm missing right now ?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
LCD iPhone 스크린 수리 키트
평생 품질 보증이 적용되는 저렴한 옵션.
키트 쇼핑하기
수리의 질 말고 비용을 절감하세요.
키트 쇼핑하기
답변 1개
선택된 해법
Do like jessa does on ipad rehab and change all the backlight circuitry good practice :)
Check another screen, maybe the leds in your one are damaged... failing that check the filters, diode, controller and coil like they say it's never the coil but it can be if it's lost some of its turns or is broken inside etc...
I have had some bad screens that are just a little dim and have a blueish tinge to the backlight
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
arbaman 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 109
