주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
487 질문 전체 보기
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
댓글 달기
답변 2개
선택된 답변
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Samsung Galaxy S6 Battery Replacement
Samsung Galaxy S6 Daughterboard Replacement
Samsung Galaxy S6 Battery 이미지
안내서
난이도:
어려움
40 minutes - 1 hour
Samsung Galaxy S6 Daughterboard 이미지
안내서
난이도:
어려움
45 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Amy ford 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 16
전체 시간: 143
