주요 콘텐츠로 건너뛰기
1.86GHz 또는 2.13GHz 프로세서, 128GB 또는 256GB 플래시 저장공간
147 질문 전체 보기
Replacing the LCD screen on the new MacBook Air
I see many sites that advertise replacement 13" LCD screens for the Macbook Air for the A1237 but I don't see the new model (mid 2010) A1369 listed as compatible. Are they the same? Can I use the same LCD screen for the new model?
Thanks,
Mike
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 6개
선택된 답변
The new machine uses the 661-5732: http://www.dvwarehouse.com/Apple-LCD-Dis...
UPDATE 8/2011
the 661-5732 can now be had for $358, new: http://www.smartmicrousa.com/apple-661-5...
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Thanks for the quick answer. It is drastically more expensive, i.e. $659 compared to ~$200 for the older screen. Are you forced to use that specific LCD screen if you were to replace it?
The part you have suggested is the whole top assembly. There seems to be a number of 13" LCD screens available for the Macbook Air if one was ok with physically removing the screen "bezel" frame, unscrew the screen and replace it. However, the replacement LCD doesn't list the A1237 model number as compatible. So, I was wondering, if these online stores just haven't updated their compatibility menus and the replacement screen really will work for a lot less money or that I'm just in a really tough spot and I have to buy the whole top assembly?
Thoughts?
Sorry, I meant: However, the replacement LCD doesn't list the A1369 model number as compatible. (the new late 2010 model).
댓글 달기
The new model is LED backlit, so you'd want to get the part specifically for the new machine. The older screens are not as good.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
maybe you can get help in an authorization apple service!
for US:
http://www.apple.com/buy/locator/
for germany and austria:
http://www.apple.com/de/buy/locator/
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The screen on A1369 is ridiculously fragile, we have had two break within 6 months from extremely minor incidents. Apple quote $1100 AU to fix!! Basically if screen breaks (and it will) laptop is useless as too expensive to replace.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Can anybody vouch for the screen being sold by Smart Micro USA? Given the difficulty finding the screen anywhere for under $600, it seems a little too good to be true. I'm also wondering whether it's LCD only or the whole display assembly. I'd read that the LCD could not be removed on this model.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The cheapest -- http://www.aliexpress.com/wholesale?Sear...
just got 1 for 250$
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mike 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 12,934
