DSi backlight wont go on!
My dsi will not turn on i charge it a day and the button goes to green but the sreen will not turn on this is what happened last time when i had a ds can you help me?
thanks,
Grace
좋은 질문 입니까?
thanks,
Grace
좋은 질문 입니까?
I noticed this problem when the top screen connection was damaged/hinge broke. Initially the screen worked but turned off intermittently, then the ribbon was damaged and the unit refused to power up... much as you describe. The LCD itself was undamaged, damage was only to the ribbon but you'll need the entire top screen.
해당 답변은 도움이 되었습니까?
Grace, you may check the fuses on your DSi and see if they are still functioning. www.tygarbyte.com gives you a great tutorial and some more on here and instructions for working on the DSi are here Good Luck to you
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,517
