I have no low beams,
I have checked the fuses and replace all four headlight bulbs
좋은 질문 입니까?
skipkuchta, Recheck bulb sockets/wires/plugs/etc. for corrosion, clean if needed, reseat bulbs and try. Check all ground wiring in vicinity of lighting circuit, check for damage, clean connections and retighten. all looks good and still no go, possibly a bad headlight switch. Check the link below to possibly solve your low beam issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
@lpfaff1 We need you on meta.
skipkuchta besides the excellent answer provided by my esteemed colleague, you also want to check the relay. From the diagram it looks like the Saturn share the Fog lamp relay with the driving light. It is located in the under the hood junction block.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 1,504
