주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2016년 3월 Samsung에서 출시되었습니다. 모델 SM-G930V.
Recent Apps & Back Key not appearing after screen replacement
I helped someone replace the display on her Galaxy S7 at a repair cafe the weekend. The repair went well, everything was working on the phone EXCEPT that the on screen recent apps and back "buttons" on either side of the home button no longer appear when tapped. Is this something that might be fixed with a reset or is this a potential problem with the display assembly? Thanks for the help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
First off, if you have a display and the touch screen works then the screen is all good. Just to be clear, do they still functionally work when touched? Or do they just not light up anymore? Or both?
Now, there is the small chance you left some adhesive plastics over the bottom of the glass the screen is attached to not allowing the light from the soft keys to shine through the glass.
You could have also potentially tore or damaged the soft keys themselves when removing the old screen.
I would be very careful and just remove the screen and see what's up, even post pictures if you want.
I doubt you have a press to press cellphones with, so taking the stuff back apart should be easy, just be very careful and take your time when removing the screen again.
When you take the screen back off you're going to notice two thing flaps on either side at the bottom that wrap around the housing and are attached to a PCB board at the bottom of the phone, where the USB port is. If you tore them, then you'll have to replace that PCB board, they are about a $20 part or so. If that's the case I'd keep the phone apart until you get the parts, make sure you put both the screen and parts in an ESD bag to prevent any damage.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thanks Jimmy! They tore those two thin flaps on either side of the PCB.
I did the same on my first Samsung. It is one i bought to practise on so not devastating. However, is it easily fixed?
If you can remove the screen without damaging it then you’d need to fit a new charge port assembly that has the back and home etc. easy if you know what your doing but 95% of the time the paint flakes on the screen making it look a mess. Cheaper in the end to get another phone with the price of ‘genuine’ Samsung screens.
댓글 달기
답변을 추가하세요
Kelsea Weber 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 35
전체 시간: 1,641
