speakers won't put out any sound
Why does it display Headphones on screen when I try to adjust volume and no sound comes from speaker?
좋은 질문 입니까?
좋은 질문 입니까?
Get a pin or something like that and give the headphone jack a good clean out.
They gather fluff up there and it could be causing the problem.
If that doesn't work then it would need replacing.
Not a massive job so it should be a cheap repair at a local shop if you aren't confident enough to do it.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 34
Are you referring to the built in speaker or did you connect an external speaker to the iphone? Then headphone icon would indicate your have a plug in the headphone connector - but what is connected? Is it a powered speaker, does it have a volume control? Does the phone normally work as a phone?
Spikey2 의
