Repairing & cleaning a water damaged LG G5 (Backlight not working)
Hello!
I recently left my phone in the pouring rain for about 10-15 minutes (long story, i'm an idiot basically) and now I'm left with a dead back light. After sitting in rice for about 3-4 days, everything was working perfectly other than the "auto" brightness option (it would just stay on whatever setting I left it at). But recently my back light decided to give up completely and I'm only able to /barely/ read my phone by shining a flashlight on it. As far as I can tell, everything else seems to be working fine!
It's been a little over two weeks since the incident (backlight stopped working 3 days ago) and I KNOW I shouldn't have waited this long to take apart my phone, but I was terrified to do it until now~
Here are some pictures of the water damage:
https://i.gyazo.com/a5e3a1bbe21b1d2a69d4...
https://i.gyazo.com/0562940839b0b1ecc7e3...
https://i.gyazo.com/fb31052e3b1e9a4048c5...
If it isn't obvious, I don't have a whole lot of an idea of what on earth i'm doing, but i'm assuming this blob (corrosion?) is part of the issue)
https://i.gyazo.com/35ddadcdf3bc2dd4f65b...
I can also unscrew the logic board if needed (:
So my question is -- Are there any areas that I need to NOT get isopropyl alchohol on? I know I need to use something stronger than 90% so I'll have to go search for that :p
And after cleaning everything, do you think if I replace the LCD screen WITH the frame attached, it will fix my backlight issue?
Thank you for any help!!
좋은 질문 입니까?
댓글 1개
Did you find out the problem?
Chris Cantu 의
