주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5 또는 3.8 GHz Core i5 또는 4.2 GHz Core i7 Kaby Lake Processor (ID iMac18,3) / Retina 5K Display. 시스템이 매우 유사하므로 이전 iMac Intel 27" Retina 5K Display (Late 2014 & 2015) 안내서를 참고하십시오.
286 질문 전체 보기
Do the adhesive strips for the 2015 iMac 5K fit on the 2017 model too?
iFixit sells item #IF174-005-1 which only shows compatibility with 5K iMacs through 2015. I imagine the 2017 models would be the same, but can anyone confirm compatibility? I have the 1TB Fusion drive and see the beachball all the time due to the tiny SSD. I'm thinking of upgrading it with an Apple 128GB or 256GB SSD and 3TB HDD but want to make sure I can seal it up again.
Thanks!
P.S. I have a 512GB Samsung 960 Evo which I would love to use, but from what I understand there isn't a good option to make it work internally (and I'm out of TB3 ports on the back so an external PCIe-TB3 solution wouldn't work). Is there anything else out there that I'm not thinking about?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
It's an A1419 . The strips will work on 16 machines running from 2012 till 2017:
http://www.everymac.com/ultimate-mac-loo...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So, just did the upgrade and the 2012-2015 adhesive strips are not an exact fit for the 2017 model. Most fit fine but the upper right strip doesn't line up with the top antenna, which seems to have been moved about an inch from previous versions. However it's close enough to work fine.
“Improvise, Adapt, Overcome” like any good Boy Scout or Marine ;-)
댓글 달기
귀하의 답변을 추가하세요
awer25 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 193
