주요 콘텐츠로 건너뛰기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
2004 질문 전체 보기
iPhone 7 screen flickering
Hello, I have an iPhone 7 screen was cracked and replaced and now the screen flickers. What causes this and how would I fix it? I also have an iPhone 6S plus that does the same.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
답변 3개
선택된 해법
Does the original screen flicker if you re-install it?
Screen flicker is usually caused by improperly seated or dirty connectors. Take a closer look, under magnification to see if there is any debris impeding a good electrical contact. You can also clean both sides (flex & logic board) of the connector with IPA (>90%). Sometimes, the retaining bracket has to be installed completely before flicker goes away.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
That looks like a defective screen. Do the IP7 and IP6S do exactly the same thing? If so, you may want to consider changing suppliers.
의견 추가하세요
Along with the flickering, it turns colors sometimes. It seems like certain colors triggers it. What do you think it would be? Maybe a cheap screen that was used?
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
I have the same problem with my iPhone 7. Bought it without the screen then i have installed in it aftermarket screen to see if it works. Then i have ordered original, refurbrished screen and it was working fine for 3 months… then it started flickering. So i have bought another screen, again refurb, and after a month without a reason it started to act exactly the same like the one in the video. What can causing my screens to die? After puttin back the aftermarket display phone is working fine…
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
CAB 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 75
전체 시간: 23,084
