주요 콘텐츠로 건너뛰기
Model A1311 / Mid 2010 / 3.06 및 3.2 GHz Core i3 or 3.6 GHz Core i5 프로세서
342 질문 전체 보기
Replacement HD won't boot
I just replaced a Samsung 500g hd with a WD Caviar 2tb hd in my new iMac 21.5 (iMac 11,2) and when it boots, I get a flashing question mark.
Do I need a Samsung hd instead of an WD?
I thought Wds were compatible.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
You need to boot from your system installation disk. Insert disk and hold down the "C" key while starting up. Go to the second page pull down menu to Utilities, Disk Utility and format the drive. Give it one partition. Now go ahead and install a system.
iMac Intel 21.5" EMC 2389 Hard Drive Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
The HD is not recognized at all and I believe it has to do with me using a different brand. I am going to get the right temp. sensor cable and see if that helps.
The OWC temperature sensor will not help you to see the drive, it will just stop the run away fan issue if you have changed hard drive brands.
댓글 달기
귀하의 답변을 추가하세요
erin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 775
