주요 콘텐츠로 건너뛰기
2016년 4월 출시 159g, 8.1mm 두께 Android OS, v6.0.1 16GB 저장 용량, microSD 카드 슬롯
73 질문 전체 보기
Swipe screen to unlock phone is not responding after dropping in water
Swiping screen to unlock my phone is not responding after dropping phone in water and drying it out. Appears touch screen not working.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
try putting it in a bag of rice overnight?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Quickly take out your device from water.
Power off /shut down your device and remove battery.
Dis assemble device if you can or if you have little skill then just remove back cover.
Now hold the device firmly as it is wet and then shake and jerk the device so that liquid can come out of your device.
Don’t use hair drier as it can heat up and can melt soldering.
Now put your device at some place for 24 to 48 hours to completely dried out. And if water is entered inside logic board then wait for 72 hours to completely dried out. And you don’t want to wait for such long time then dis assemble the device completely and rub entire logic board with soft cotton or brush and use alcohole or propelyne or any logic board circuit cleaner advisable for electronics component. This can remove any corrosion on circuit board.
Now assemble the device and power on it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Paul Cobb 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 327
