Phone won't switch on
Phone won't turn on even with forced reset
좋은 질문 입니까?
can you try a new or a friends S4 battery? If you plug in the charger and can see the battery charging or the battery logo it may be the power button. Galaxy S4 have a power button that will need to be soldered on in order to replace the Button. the only way to test the button is by opening it up and testing the button itself for continuity on the connectors. If the charging port is bad and not charging the battery it may not turn the phone on. try another charging cable also just to rule it out. hope this helps.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 50
