주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2686 질문 전체 보기
What to do with the adhesive around lcd connector
After doing a screen replacement does the adhesive interfere with the repair process. I’ve was in the process in replacing an LCD, I had the battery plugged and that’s when I’ve smoke rise up after I had connected the lcd cable. The smoke had came from the lcd connector and smell burnt. Was the mistake was because of the adhesive or battery not being disconnected while in the process of repairing.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
The adhesive has nothing to do with it. The iPhone 6S is very prone to backlight circuit blowouts. You have to disconnect the battery first otherwise you can short the pins of the connector if they aren't lined up properly.
You will have to find a repair shop that does micro-soldering repairs to fix your backlight circuit. This is not a DIY fix.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Sorry, I was typing my question in a hurry. Didn’t realize I had forgotten few words, until now. Thanks, I just notice the pins of the connector wouldn’t snap in easily. I was struggling during the process of plugging it in, that’s when I’ve seen smoke coming out of the connecors. One more thing, if the cables aren’t connected properly, once i plug the battery back in. Can I blow out the circuit in that way?
Sure, if the connector is misaligned and you connect the battery, the same thing may occur.
댓글 달기
귀하의 답변을 추가하세요
Osvaldo Banda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 75
