Laptops manufactured by Toshiba.
1017 질문 전체 보기
Adobe reader error when opening document
When you click on the button "Open" a pdf document is issued :"there was an error opening this document. Can't find file."
What could be wrong?
Asked the user to check for viruses. He said to periodically check for viruses (Kaspersky).
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Thank you guys for your feedback and help. Thank you!
의 답변
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
3개의 답변
선택된 해법
If you open any other pdf file in the same way error also occurs?
Just try to update Acrobat to the latest version. Or put, for example, Sumatrу. If you do not help this method, then you can restore the file using PDF Repair Kit for adobe pdf repair. http://www.adobepdf.repair/
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
Is it just that one file or is it all PDF files.
If its just that file, that file may be damaged or is gone.
If its all, uninstall Adobe Reader and reinstall it again.
If that doesnt fix it let me know and we will find other options
해당 답변은 도움이 되었습니까?
점수 1
댓글:
Is it just that one file . and I also think it's damaged
의 답변
If it is, its definitely damaged and there is nothing you really can do.
의 답변
의견 추가하세요
Hi @ernobalog,
First,
1. You can try to move on from older version to latest one.
2. Cross checked once, are you not rename his file along with extension?
if you still stuck, It may be possible that for some special configurations, such as:
1. Mail client you are using?
2. Do you have roaming profile/redirected folders?
3. Do you have any anti virus/secuirty software installed?
You can try, repairing Reader X installation from Help-> Repair option
If you are getting this issue again, recommend to call my toll-free number +1-800-620-8060.
Cheers
John
해당 답변은 도움이 되었습니까?
점수 0
댓글:
I'll try to follow your instructions. thank you!)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
ErnoBalog 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 33
전체 시간: 1,057
