주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
I repaired my dock connector on my iPhone 4S but it won't charge
Hello. I recently purchased and replaced a dock connector for my iPhone 4S that had a broken power button and dock connector. However, when plugging the phone in, I get nothing on the screen (when using my wall charger, portable charger or back of PC) and nothing in iTunes - on the PC I do not hear a device connection sound. When using the front USB ports I get a "Device Descriptor request failed" but I do hear the device connect sound. What could be the issue?
Small edit: the phone hadn't been switched on for around two years because the dock connector had broken
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
And if this does not help then the replacement charging port is faulty and needs to be replaced with another one. I think the battery is FINE.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
hey
you need new battery as well and try to put the dock flat with the connector properly
good luck
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
InvoxiPlayGames 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 52
