Why the car is consuming more fuel
The car showing no other symptoms.but the fuel consumption is double than usual.
좋은 질문 입니까?
좋은 질문 입니까?
A more detailed question should be asked. What type of engine. Is the check engine light on. When is the last time you had a tuneup? My guess is never...
Double the fuel consumption you either have drag (issue with the brake system, seized calipers), sensor(s), fouled plugs, air filter clogged, vacuum leaks, a fuel leak, under inflated tires. Although it won't be a tire issue..
My guess is start with a tuneup, plugs, filter etc..
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 4
30일 전: 11
전체 시간: 1,190
